Moys1.9
Bleeding Brakes
Moys1.9
Fitting a new rear calliper this week. I'm familiar with the process of bleeding the brakes when refilling the system however was wondering is it ok to leave the cap off the brake reservoir when pumping up the pressure?
jim21070
  pdd144c said:
Yes.
But for no longer than absolutely necessary, to avoid atmospheric mosture being absorbed by the fluid, whicjh is bad news. On the same token, keep your bottle of new brake fluid tightly capped at all times, except, obviously, when you are using it to top-up the fluid reservior!
