pugpete1108 62 1 Cars Posted October 1, 2006 just looked at my 6 and noticed it has a coil on each plug ,is that right?. with two low voltage cables feeding it , do i keep these for the emerald ecu or go for a wasted spark set-up using normal ht leads and ford coil? just checked the emerald manual and it doesn't really state wether you can fire plugs sequentially , but surely if the gti-6 was designed to do this then using wasted spark will see a drop in power/performance? Share this post Link to post Share on other sites
pugrallye 0 Posted October 1, 2006 dont see how you would get a drop in performance using wasted spark?? Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted October 1, 2006 dont see how you would get a drop in performance using wasted spark?? thats cool then , just checking . i take it i could use the original coils and just wire 1&4 cylinders and 2&3 cylinders and connect to the corresponding ecu drivers? Share this post Link to post Share on other sites
pugrallye 0 Posted October 1, 2006 (edited) well yeah to coil drivers if emerald doesnt take care of that side of things Edited October 1, 2006 by pugrallye Share this post Link to post Share on other sites
