pugpete1108 62 1 Cars Posted September 28, 2006 what wiring is suitable for wiring my emerald ecu i have brought 50m of 40/0.30 (1.0mm ) rated at 8.75 amps do you all think this is suitable? Share this post Link to post Share on other sites
Craigb 2 Posted September 29, 2006 Emerald suggest 0.5 for the ecu supply 1.0 for the ecu earth 0.5-1.0 for the acutators ( coil, injectors) 0.5 for the sensors twin core shielded for the crank sensor Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted September 29, 2006 Craigb said: Emerald suggest 0.5 for the ecu supply 1.0 for the ecu earth 0.5-1.0 for the acutators ( coil, injectors) 0.5 for the sensors twin core shielded for the crank sensor so what i've cot should be suitable for all applications, cheers i should have checked their manual first Share this post Link to post Share on other sites
Craigb 2 Posted September 29, 2006 I did the same as you , all mine is 1mm so should be ok Share this post Link to post Share on other sites
miamistu 1 Posted September 30, 2006 pugpete1108 said: what wiring is suitable for wiring my emerald ecu i have brought 50m of 40/0.30 (1.0mm ) rated at 8.75 ampsdo you all think this is suitable? You're doing all your wiring the same colour? Share this post Link to post Share on other sites
Dream Weaver 2 Posted October 2, 2006 I mixed 0.5 and 1.0 thinwall from VWP, and bought lots of different colours. It cost about £115 for all the wiring, connectors, crimp tool etc Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted October 2, 2006 miamistu said: You're doing all your wiring the same colour? yup , figured it will be easier/cheaper than using loads of different colours , they will all be numbered at the ends anyhow , and when they are all wrapped you wont be able to tell. 'mixed 0.5 and 1.0 thinwall from VWP, and bought lots of different colours. It cost about £115 for all the wiring, connectors, crimp tool etc' yeah i did look on there but it seemed lots of hastle instead of just buying 1 or 2 rolls to do the whole job and seeing as its £12 for a 50m roll i cant grumble Share this post Link to post Share on other sites
Dream Weaver 2 Posted October 2, 2006 (edited) You'll wish you got multi colours when you start making it though My original loom was all one colour and was a complete nightmare!! The new loom is brilliant with a single colour for every wire - the numbers *WILL* fall off when you route the loom Edited October 2, 2006 by Dream Weaver Share this post Link to post Share on other sites
miamistu 1 Posted October 2, 2006 Dream Weaver said: You'll wish you got multi colours when you start making it though My original loom was all one colour and was a complete nightmare!! The new loom is brilliant with a single colour for every wire - the numbers *WILL* fall off when you route the loom Agreed - it's not much money and the hassle it'll save in the long run is huge. Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted October 2, 2006 i'm sure i will regrett it but what the hey we will see the numbers shouln't come off as i will be using cable tied numbers borrowed from the engineer stores at work Share this post Link to post Share on other sites
Rippthrough 98 Posted October 11, 2006 pugpete1108 said: i'm sure i will regrett it but what the hey we will see the numbers shouln't come off as i will be using cable tied numbers borrowed from the engineer stores at work Cheaper way to do it is to buy a nice 100m roll of wire (~25quid for decent stuff) then go to screwfix direct and buy a couple of different colours of PVC sheathing ( self extinguishing too, which is handy) @ 5.00 each. Little bit of time to thread the wiring through but saves a lot of money. Share this post Link to post Share on other sites
