Guest darren1984 Posted September 28, 2006 Hi guys, Have a bit of a problem, I have an s16 engined 205 and my exhaust has started to blow pretty bad so i thought id get the welder at it to sort it out but when i got under the car i found a weird set-up,basically the downpipe turns into 2 pipes were the rest of the exhaust system bolds on and then it goes back into 1,im thinkin of gettin a new exhaust but is this normal or is it only because of the s16 engine? Im a little confused,can anyone help? THanks alot Darren Share this post Link to post Share on other sites
Baz 421 Posted September 28, 2006 Sounds like you have an after market downpipe from what you've said above. iirc Janspeed make a twin pipe downpipe but isn't actually all that good. Itdefinately isn't an S16 thing. If you mean the manifold, then yes this has a split in the centre (inside) and so should the downpipe (but still be one round pipe). This acts like the 2-1 part of a 4-2-1. HTH a little!! Share this post Link to post Share on other sites
welshpug 1,666 Posted September 28, 2006 all the larger capacity o.e XU downpipes IIRC are split but look like a single pipe from the oitside (bar the weld going down the side) smaller ones or non Sport ones have been 2 separate pipes. Share this post Link to post Share on other sites
Guest darren1984 Posted September 28, 2006 So if im ordering an exhaust what one do i order? im confused..haha Thanks lads!! Share this post Link to post Share on other sites
Baz 421 Posted September 28, 2006 A standard 205 Gti one. There are two types, pre '89 which were a downpipe that connected to the centre section,(3 pc system) or a post '89 that are the downpipe incorporated with the centre section.(2pc system) Ideally you want a good one like Arvin, as they have the split down the centre on the downpipe which is beleived to be very beneficial. Share this post Link to post Share on other sites
Guest darren1984 Posted September 28, 2006 Ah thanks baz, So the manifold just connects onto a down pipe,i thought i might have to take the manifold and all off..pheww..haha Thanks!! Darren Share this post Link to post Share on other sites
