Guest s.odedra
Keypad Wiring
Guest s.odedra
hey all
need ur help in wiring up a keypad for a 2.0 lt turbo from a 406
on the keypad theres 15 pins, and hear that i only 6 of them need to connected
pin 1 = bmf4 = connected to live +
Pin 3 = 820 = connected to pin 50 on the ECU (820)
Pin 4 = 821 =connected to pin 2 on the ECU (821)
pin 13= co2 = ??????????
pin 14 = 822 = connected to pin 50 on the ECU (820)
pin 15 = m8200 = earth
not sure about pin 13
please help
sonofsam
pin1=bmf4j battery live
pin2 = nil
pin3 = 820 diag plug (match with number on wire to ecu)
pin4 = 821 diag plug (match with number on wire to ecu. sometimes joined
with pin3 on keypad a short way up the loom)
pin5 = 1031 live while cranking, probably ignore for now
pin6 = nil
pin7 = nil
pin8 = 824 (match with number on wire to ecu or ignore for now)
pin9 = 6219 central locking, state changes when locked, ignore for now, may
prevent rearming if left off
pin10 = nil
pin11 = 3050 (not sure, probably central locking. ignore for now)
pin12 = nil
pin13 =c02 ignition live
pin14 = 822 output to main relay coil. live when immob deactivated (max
300ma, recommend use bulb to limit current while testing)
pin15 = m8200 mass (earth)
Courtesy of Fuqa.
johnrobertgordon
or you could buy my unlocked ecu off me, you would not need a keypad then.
sonofsam
I'd keep the keypad personally, wish I had the chance to, but my loom was so butchered i had no chance!
Good bit of extra security in my mind:)
Scrapping your turbo already John?:P
johnrobertgordon
No way Sam, i'm fitting an emerald :P
max0
cant your remove the keypad once its started and you dont need it again?
johnrobertgordon
there are a million different stories, all i know is that mine would not work unless i had my ecu unlocked.
Guest s.odedra
thanks all
GOT it workin :P
only had to put the code in once and thats it...
car sounds LOUD as theres on exhaust on it hope to have it on the road running very soon
sonofsam
Nice one :D Yep choffin loud with no 'zorst!
inferno
unlocked being removing te keypad when engine is running :D
imo the keypad is a good idea, u can always delock it if it bores you after a while!
