saveloy
Running Very Rich
saveloy
Apologies, this is not 205 related.
I have a friend with a 1997 Subaru Impreza STI 3.
He is suffering with a problem with over fuelling. The car is throwing alot of fuel into the 2 offside injectors. Enough to soak up the plugs. The ECU light will pop up, but the ECU won't throw up any fault codes.
I have wondered if it is a problem with excessive fuel pressure. And the easiest outlet is the 2 offside injectors. Perhaps it is a fuel regulator issue, or a pressure relief valve, if one exists.
Has anybody any ideas? Or, better still some Scooby experience.
Sam
Could it be the MAF sensor, they are turd on the subarus.
saveloy
I don't think it's the MAF sensor. Only the 2 injectors are over fuelling. I wouldn't have thought each bank ran independently.
