jonnie205 1 Posted September 24, 2006 Having probs wiring in a gti6 oil pressure switch. The gauge does not seem compatible with the gti6 switch on engine. The last conversion i have done have been on stack dashes which seemed to work fine but have people used the 8v or mi16 switches on the gti6 engines to make oil pressure gauge work? I assume an adaptor is needed to screw gauge into block? this adaptor would also have to replace the oil pressure light sender? many thanks Share this post Link to post Share on other sites
sonofsam 5 Posted September 25, 2006 Is this the kind of adaptor you mean Jonnie? I have one somewere to fit , got it from DemonTweeks. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted September 25, 2006 Most gti6's only use a low oil switch and the oil pressure hole is blanked off, use a S16 sender in the hole Share this post Link to post Share on other sites
whizzer71 0 Posted October 5, 2006 I used a Zx16V pressure switch in the hole thats blanked off somewhere near the starter motor. Tris Share this post Link to post Share on other sites
welshpug 1,677 Posted October 5, 2006 whizzer71 said: I used a Zx16V pressure switch in the hole thats blanked off somewhere near the starter motor. thats what miles said last week Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted October 13, 2006 sonofsam said: Is this the kind of adaptor you mean Jonnie? I have one somewere to fit , got it from DemonTweeks. is that an 8v sensor fitted in the top ? and why have you kept the gti6 sensor? Share this post Link to post Share on other sites
sonofsam 5 Posted October 13, 2006 pugpete1108 said: is that an 8v sensor fitted in the top ? and why have you kept the gti6 sensor? Not my engine, but yes thats an 8v sensor in the adaptor on a 2.0L T.Not entirely sure the pressure part of the gauge works on that set-up.The other bit is for the light is it not? Share this post Link to post Share on other sites
mbayley77 0 Posted October 13, 2006 Yes the horizontal part is for the light. I dont see why this shouldnt work for the guage though??? Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted October 14, 2006 mbayley77 said: Yes the horizontal part is for the light. I dont see why this shouldnt work for the guage though??? are you using this set up? Share this post Link to post Share on other sites
