c_r_thomson 0 Posted September 24, 2006 Hi all, i'm fitting carbs at the mo and i'm trying to get rid of as much wiring as possible. What does the fifth lead from the dizzy do and can i get rid of the tachymetric relay? Cheers, Craig Share this post Link to post Share on other sites
pug_life 0 Posted September 24, 2006 5th lead is king lead to the coil. you need it to get a spark. Share this post Link to post Share on other sites
c_r_thomson 0 Posted September 24, 2006 (edited) so is there a better way of connecting it? the fifth HT lead from the dizzy went to a plastic box on top of the inlet manifolt which has now been removed. The plug from the dizzy goes to the ignition module and the relevant interconnections from there to the coil, rev counter, etc. I shouldn't need to use the setup with the fifth HT lead should I? Ahhh SH*T! I think i've just realised what i've done! That plastic box is the coil!?!?! Can any one tell me what pin is what cos i'm gonna have to rewire it in now since i've removed the loom. So if this is the coil,....... what is the small cylinder on top of the starter motor? Edited September 24, 2006 by c_r_thomson Share this post Link to post Share on other sites
hengti 2 Posted September 24, 2006 (edited) might be missing something here, but why have you taken the coil off if all you're doing is fitting carbs? i realise the inlet manifold will be different, but you need a coil!! Edited September 24, 2006 by hengti Share this post Link to post Share on other sites
c_r_thomson 0 Posted September 24, 2006 Got a bit trigger happy with the snips today!! Share this post Link to post Share on other sites
welshpug 1,666 Posted September 24, 2006 might be missing something here, but why have you taken the coil off if all you're doing is fitting carbs? because on later engines the coil is mounted on the intake manifold. Share this post Link to post Share on other sites
c_r_thomson 0 Posted September 24, 2006 Thanks welshpug, i need to find somewhere else to mount it now, Just gotta rewire it first Can any one help me identify what pin is for what? Share this post Link to post Share on other sites
welshpug 1,666 Posted September 24, 2006 what you need is one that mounts where the earlier ones did, on the inner wing next to the ignition amp. this did the job perfetly when I replaced the coil on my car, its identical in spec to the original unit but is actualy just an universal jobbie that Euro Car Parts sell complete with the bracket and the finish on it is outstanding! Share this post Link to post Share on other sites
