Kennyb
Flicky Needle Syndrome
Kennyb
Doe's anybody know what cause's or how to fix the flicky speedo needle problem that occurs on the old pug??? I've had 3 of them with this problem and haven't found out how to fix it :-( Please help
Guest rick03054
Try a new cable. They sit near the exhaust manifold so apparently dry out, infact one of mine has melted! :)
Jonmurgie
Yeah, common problem with the 205's I'm affraid, and sometimes new cables only last a few months before the flick is back :ph34r:
Try a search as although not covered recently I know there were some threads about with some custom cable heat covering thing or other :)
IIRC one person tried this, they spent in the region of £100 on some heatshield and it made no difference ultimately.
If you want a steady speedo in a 205 you need to buy a left hand drive one which has a shorter cable routed in a straight line from the gearbox to the clocks :P
KRISKARRERA
Yeah that was Rich E that did that.
309 and 405 does it too, in fact mines been doing it for 3 years now but the cable still hasn't snapped... yet.
Ryan
Can't you re-lube the cable? I keep meaning to take mine out and try it...
Rom
Yes you can. I had my clocks out to change a bulb,used a little oil squirted to drip oil into the cable. Use engie oil or similar as it doesnt dry out as fast as WD etc. Lasted a few months, starting to come back now though.
Guest BrainFluid
Do the Gtis's use a moving cable and not an electro wire for the rev counter then?
If its the latter, would using a thicker gauge wire help at all?
My Td has a wire for the revs should i consider bypassing the loom with a nice fat wire. Mind you csimply cleaning the contacts would help no end I imagine!
Alastairh
There doesn't seem to be much of a long term fix.
I just take it as part of the character of a 80s French car....
KRISKARRERA
Might as well just buy a new cable and save the oiling for when Peugeot stops making it.
Rom
Yeah there the old style, not this new fangled electronic malarky :blush:
Daxed
Bit of confusion creeping in here between tacho and speedo.
DaveW
£22 for a speedo cable from Pug last time i got one.
Rom
Yeah sorry, misread BrainFluids post. I was thinking he was on about electronic speedo senders, not tacho
mos
Hi,
i am suprised no one has mentioned the plastic gear at the top of the gearbox that the speedo cable mounts in.
i my experience the cause of the flicky speedo needle has either been this red plastic gear or the cable itself.
in 10+ years of 205 ownership, including repairs to friends and familys cars as well as customers of my friends garage i have never come across a car that after replacing both the speedo gear (about £6 from peugeot) and the speedo cable still had a flicky needle.
the new parts have always lasted a good few years as well, even in vehicles covering big miles.
miles of flickerless driving!!!
thanks
mark
tomodling
My one flickered and flickered in my last pug before the cable eventually snapped.
It now does it in my new car. I see it as a "Characteristic" of a 205, a bit like the rattles :D
tom
mos
Hi,
you do not actually have to live with this you can sort it!!!
thanks
mark
