Bam 0 Posted September 21, 2006 hi, i'm unsure...wich piping diameter would you sugest me? 50mm.... or 60mm ? 1bar stock pressure ~250hp 1,5bar in overboost ~300hp. 50mm would be fit perfect..i think i have a little clearance problem... cheers mik Share this post Link to post Share on other sites
Bam 0 Posted September 21, 2006 rs 500 intercooler (~10L) 600x400x30 Share this post Link to post Share on other sites
Jonmurgie 2 Posted September 21, 2006 Just use what you can fit really... RS500 intercooler is a touch overkill IMO... If 50mm pipe fits best then use that Share this post Link to post Share on other sites
welshpug 1,676 Posted September 21, 2006 i'd guess you'd want the same diameter as your throttle body to minimise the bottlenecks in the intake tract? Share this post Link to post Share on other sites
sonofsam 5 Posted September 21, 2006 Im using 2.5" ( 64mm ) on mine , as its the same size as the standard XU10 T. Throttle body and intakes. 50mm for 300hp may be a touch restrictive!But atleast you would have a shorter inlet tract. Share this post Link to post Share on other sites
Bam 0 Posted September 21, 2006 forgot something: i have a custom inlet manifold.TB=85diameter. has anybody a formula to calculate the perfect boostpressure diameter? i think, i will winn responsetime (intercooler is very big) Share this post Link to post Share on other sites
TEKNOPUG 3 Posted September 21, 2006 Surely there is a correlation between the diameter of pipe you use and the boost pressure you will create? For example, if you use a small pipe, you will require less air to get a certain boost pressure at the other end than you will if you use a really large pipe? I'll try to dig out some info that I have on this at home. Share this post Link to post Share on other sites
sonofsam 5 Posted September 21, 2006 I would of thought a larger diameter would help decrease loss of boost pressure coming from the intercooler. Share this post Link to post Share on other sites
welshpug 1,676 Posted September 21, 2006 up to a point, imagine blowing through a straw, then a sink waste pipe, then a drain pipe. the sink waste pipe is most effective, the straw doesnt flow very well, and the drainpipe has too much air in it for the pressure to move it. Share this post Link to post Share on other sites
sonofsam 5 Posted September 21, 2006 Gotcha! Great anology there. Share this post Link to post Share on other sites
