jim205GTI
Tilted Rad
jim205GTI
Tilted the rad to clear the inlet manifold which it does but now have another problem the secondary catch ( the one opened from outside) catches the top of the rad and so won't let me shut the bonnet! :) Is there anything i could do to cure this problem bar removing the catch and fitting bonnet pins?
cheers jim :D
Daz_C
I bent mine over again and had no probs after that.
May help to heat it up first as I found it made it easier to bend.
jim205GTI
Ah i think i see what you mean i'll go have a play and see what i can do cheers
