Jonmurgie
Mi16 Water Housing Sensor Identification
Jonmurgie
Wiring and stuff is NOT my thing, so can someone confirm what each of the 3 sensors in the Mi16 water housing are for:
Jon (feeling a bit thick really!)
blue two pin one is the ecu temp sensor, the two single spade connectors are the coolant temp gauge sender and the overheating warning light sender.
Jonmurgie
Splendid... I guess I had an idea of that but thanks for confirming it :)
Ryan
And out of the 2 spade connectors the one on the top edge of the housing is the warning light (it will have the temperature rating stamped on the side), and the one on the side is the sensor for the gauge.
steve@cornwall
Thank's all, saved me from asking!
