d7ve_b
Ignition Amp And Coil Part No.'s
d7ve_b
As stated I need the part numbers for the ignition coil and amp for a D'Plate Ph1 1.6 GTI, does anyone know them?
Before I get flamed, i've searched for both and to my surprise they both returned no results, I'd have expected at least a couple? :)
Thanks in anticipation....
d7ve_b
Many thanks for that, but I was expecting the part numbers to be of a different format? For example the replacement ignition module I am looking at is numbered 0 227 100 123 ??
The diagram is very useful so thanks again for that.
Jonmurgie
The part number you are quoting is the Bosch number as the parts are very interchangable... you asked for the part numbers and I assume you mean the ones from Peugeot for you to order them?
d7ve_b
Ah ok, sorry about that. There is an ignition coil and some ignition amps on ebay that I was considering buying and I just wanted to check the part numbers quoted...
Coil
Amps
Craigb
I've just been doing a search for a replacement coil
OEM Peugeot £53 +VAT
Motor Factors £16.91 + Vat
In this instance is it another case of getting what you pay for ?
Are there any other stockists of genuine Bosch parts ?
V8Pete
I tried to buy an ignition module for my 205, but it had a different connector to the one already in there.
At the moment it's got a Ducellier module (with MTR01/2528008 on it), Ducellier coil on the inlet manifold, and Bosch screw-on distributor cap.
The replacement the shop ordered in has 3 terminals in a row, then another two at 90 degrees to take two separate plugs. My current plug has 6 terminals and 7 holes in one row.
Any ideas?
Would a Bosch BIM 123 be suitable?
Over here genuine Peugeot is ~£200 with 6 week wait, from BNT, ~£30
Edited by V8Pete
all pug fitting modules I can remember seeing are the 7 pin type, like fitted to your car, IIRC some very early 205's used the 5 pin example you have been supplied.
the 7 pin module is generic to many PSA products, Mi16, S16, ZX16v and others have two!
V8Pete
Thanks for clearing that up.
Another thing, I couldn't find the module on my later 205 GTI parts car. Do they have a different system or something? It still has the same distributor and coil - or has some cheeky bugger moved it?
Edited by V8Pete
