Bam
Digital Boost Pressure
Bam
hi,
i doesnt find any good place to fix a standart 52mm analog boost pressure.(into 205 309)it looks so...attached. :(
i think a little digital boost pressure would be nice... :wub:
but...has anybody a selfmade digital boost pressure?any instructions? or where can i buy it for lowbudget?
cheers
mik
sonofsam
I didnt think there was such a kit.
Maybe get in touch with these guys :http://www.velleman.be/be/en/product/list/?id=342508
Besides there are plenty of places to tuck a analogue boost gauge in.
TEKNOPUG
I'm not sure how useful one would be. Unless you're running huge boost the numbers would change so fast that they wouln't make much sense. Much better to have a dial read out. You can certainly get digital boost sender units. They take the boost feed via a line and then send a digital signal to a gauge. They can record things like peak boost etc. However, they still normally use a dial gauge for the aformentioned reason.
Malachy
i think i know a way of doing this using megasquirt and having a linear output into a panal voltmeter. (i done a similar thing for an afr gauge on my LC1)
use a 0-2v output with 0vs being 0 boost and 2v being 20psi, put this into a panal meter and adjust the voltmeter so the decimal place reads 20@2v
although as already said i dont think a digi boost guage would be much good you need fast visual readings,
a sweeping dial, a row of led's something like this.
