matt gti78
Over Torque Headbolt
matt gti78
Guys,
I'm miffed at the moment :( , over the last 3 weeks bit by bit I took the cylinder head off, to replace the valve oil seals and all the gaskets.
While following the haynes manual on refitting the cylinder head bolts, it states the following, though some of you might know already:
Stage 1 - 60nm
Stage 2 - After slackening - 20nm
Stage 3 - Angle 300 deg's
While doing stage 3 on the back right headbolt (No.9) it went to far and stripped the bolt, at this time I thinking the engine is F****d, but someone has told me about a recoil kit which I thought you could never use on something like a cylinder head.
So what I need to know please, is can a recoil kit be used to create a new thread and will it hold and will I need to replace all the headbolts again.
Also is there another way of tightening the bolts other than using haynes instructions :wub: .
PumaRacing
You might wish to read my website.
matt gti78
I'm sorry I missed lead you, it's the threads in the block that has stripped out.
My Father suggests using a re-coil kit with a coil length of approx. 25mm. But worries if this will hold using the Haynes method in tightening the head bolts. But thinks your method would be a better option of tightening the headbolts.
inferno
generally i tend not to use helicoils for anything! although a mate who works with ducatis swears by time serts... aparently they can hold a 916 head together. so i used one on a clio 16v gearbox mount, and it appeared to be ok!
the bolt must of cused damage for a reason... was there water in the hole? or was it the bolt that needs a spacer?
as for using a helicoil on it, ill leave that to some1 with more experience... id say no ... but it may have been done.
M3Evo
None of the holes are blind so water being in one is a non starter.
matt gti78, look at Pumaracing's website for info on torquing the head as he says, there is another way from the Haynes! :)
gtimon
Hi,
I'm new to this site and reading various topics,
but I don't understand the meaning of the above quote ??
jim21070
Hi,
Hi and welcome!
What is meant here is that all the head stud holes go right through and are open at the end, therefore it is not possible for water to settle in them and cause a hydraulic lock when torquing down the studs and stripping the threads as a result.
If you look on the block, you can see the very ends of each head stud poking out of their respective holes.
Hope that helps...
