shings 0 Posted September 15, 2006 "NB I have tried searching but cant find the exact answer I want" Right I need to know what brakes calipers are the same as the 306 GTi6 calipers? A rough price and where to get them from? Thanks jake Share this post Link to post Share on other sites
TEKNOPUG 3 Posted September 15, 2006 None. Well that's not strictyl true. The 306 Rallye calipers are the same. Share this post Link to post Share on other sites
jimbean 0 Posted September 15, 2006 come on... a 306 rallye is is a gti6 without electric 406 hdi 110/ 406 2.016v 307 hdi 110 xantia 110 hdi and 2.0 16v but has hand brake on front all these callipers wre the same size as the gti6 Share this post Link to post Share on other sites
willxs 0 Posted September 15, 2006 same size, but not the same shape.... if your including the yokes Share this post Link to post Share on other sites
smighall 1 Posted September 15, 2006 Only other car to have the same brakes was the Xsara VTS. The 307 HDI brakes have a slightly smaller piston IIRC. I think they are the same size as on some 406's but the yokes are different. Share this post Link to post Share on other sites
mi16nut 0 Posted September 16, 2006 The 307 HDi are designed to work with 26mm thick discs, not 21mm as on the GTi6. They have smaller pistons too; 54mm against 56 or 57mm I think, so tend to work better with standard 205 master-cylinders. Mark. Share this post Link to post Share on other sites
Phil H 16 Posted September 16, 2006 (edited) Only other car to have the same brakes was the Xsara VTS. The 307 HDI brakes have a slightly smaller piston IIRC. I think they are the same size as on some 406's but the yokes are different. re the 406 callipers...so you just need the 307 283mm discs & pads and the 307 yokes? Theres loads of 57mm Lucas callipers at my local breakers and would be nice to get some if I only need the 307 yokes. You can see the 406 discs wont fit as the hub is almost flush with the disc. Edited September 16, 2006 by Philip Hills Share this post Link to post Share on other sites
Ahl 4 Posted September 16, 2006 re the 406 callipers...so you just need the 307 283mm discs & pads and the 307 yokes?Theres loads of 57mm Lucas callipers at my local breakers and would be nice to get some if I only need the 307 yokes. You can see the 406 discs wont fit as the hub is almost flush with the disc. Thats right, but 306 discs and 306 yokes. 283mm 307 items are similar but not compatible. Try getting cheap 306 yokes though. Share this post Link to post Share on other sites
