PugAddict 0 Posted September 14, 2006 Quick Question......... What distributor is needed for a 1990 205 GTi with a 1.6 head and a 1.9 bottom end? Would the dizzy from a 1988 1.9 GTi do the trick? What are the differences between the pre-91 1.6 & 1.9 dizzys? Cheers dudes Share this post Link to post Share on other sites
welshpug 1,666 Posted September 14, 2006 the heads are identical pretty much, mechanically the dizzys are also identical IIRC bar the cap (up to mid 88/88on) though 1.6-1.9 dizzys have a different curve. have you swapped the 1.9 cam over? Share this post Link to post Share on other sites
matty_gti 20 Posted September 15, 2006 hmm, im in the same boat....allmost, i have a 1.6 gti, which im building a 1990 1.9 8v engine for, however can i use the 89 1.6 dizzy ive taken off the original engine to be used on the 1.9?. Share this post Link to post Share on other sites
welshpug 1,666 Posted September 15, 2006 yes, it will fit, but no it wont suit the engine. wrong advance curve. but for how much it costs and how old the dizzy is you might as well get it rebuilt with the right curve in it. Share this post Link to post Share on other sites
