Guest ashnicholls
Leaky Sump
Guest ashnicholls
I have just rebuilt the engine with new sump gasket, and used a gasket sealent either side of it.
I ensured both surfaces were clean. And torqued the sump up to torque setting in the Haynes manual.
But it is still leaking.
What shall I do?
Torque it up some more? Im just always scared of stripping threads on blocks.
Cheers Ash
sorr
The first time I did mine a gasket and sealant was used, and it leaked. Replaced it with a gasket only and no more leaks.
This may sound odd, but I think the problem is that too much sealant is used, you actually need very little for a seal.
To answer the question I would try a new gasket and not just tighten the bolts more. Given the number of bolts there will be considerable pressure put on the gasket with the bolts at the correct torque so if it does not seal now it is unlikely it ever will.
Assuming you have a 1.9 are you sure the leak is not between the spacer and the block?
Edited by sorr
Guest ashnicholls
No its a 1.6 with no spacer plate. And I did only use a very small amount of sealer???????????????
And its defo from the sump, as its bubbled through the sump paint.
rescue dude
Took me three attempts to get my 1.9 under control.
I now don't fill the oil to the max on the dipstick and warm the engine steadily before i push it.
Seem's to have got it well under control. ( he say's touching every wooden object in sight. )
The gasket's compress over the first few day's and need nipping up, But I never ever use gaskets as they are a pain to clean when you take the sump off, Wurth RTV is a winner evey time, Noting else I have found works
Grim.Badger
Not long done mine with just the gasket between the sump and spacer and sealant between the spacer and the block. There's no leak between the sump and spacer but there is weepage between the spacer and block so I'd try it again with just the gasket if I was you.
This was the first time I'd done this so I'm surprised I did such a good job :ph34r:
boombang
Never used a gasket here either, and again no problems - strangely enough use RTV too :ph34r:
Just have to put the sealant in the right places.
