matty_gti 20 Posted September 12, 2006 (edited) hi all, just asking is there a certain oil i should use when rebuilding my 1.9 8v engine or any old cheap stuff, i heard its better to run part synthetic than full synthetic becasue its just to thin???....i was using 5w 40 fully synthetic with a purflux oil filter form Peugeot before in my 1.6 until she died ..... however i will be fitting a group A oil pump spring to the 1.9 because i know a few people that have them and for just piece of mind I am about to fit together the bottom end which i get back from the engine builders end of this week, ill have new mains and bigend bearings, and a nice lightend + reground crank, therfore ill need to know which oil i should use when covering the whole bottom end in it. Edited September 12, 2006 by matty_gti Share this post Link to post Share on other sites
matty_gti 20 Posted September 12, 2006 O and i just bought another 1.6 GTi to be my new runaround while i rebuild my 1.9, so my qeustion is i had a K&N induction kit on the my other GTi and i want to move it to the one i just bought, however the car it came form is not power steering and the new one is, would it matter if im fiiting it behind the passenger headlight??? ThAnKs Share this post Link to post Share on other sites
richard 0 Posted September 12, 2006 Thats where mine sits...and where most of the gti's ive seen have them. No manifold heat soak there! Share this post Link to post Share on other sites
matty_gti 20 Posted September 12, 2006 yeah thats what i thought, but its says 'PAS and NON-PAS kits, so i thought it may of sat over the exhaust manifold like ive seen a few. Share this post Link to post Share on other sites
matty_gti 20 Posted January 17, 2007 Getting back to the oil q....is part syn or fully syn better for my rebuild and what '?W-??' is best...and should i use 'assembly lube'? Share this post Link to post Share on other sites
Banjo 1 Posted January 17, 2007 Have you honed the liners and are the piston rings new? Share this post Link to post Share on other sites
jackherer 543 Posted January 18, 2007 yeah thats what i thought, but its says 'PAS and NON-PAS kits, so i thought it may of sat over the exhaust manifold like ive seen a few. The PAS kit has a bracket for the reservoir, thats the only difference, the filter fits in the same place. Share this post Link to post Share on other sites
matty_gti 20 Posted January 18, 2007 Have you honed the liners and are the piston rings new? Yeah the liners have been honed and yes the rings are new.... Share this post Link to post Share on other sites
petert 601 Posted January 18, 2007 (edited) Updating to the 26T sprocket from a 2L (and 52T chain) is more important that upping the pressure. Spinning the pump faster will improve low rpm pressure. Pour a tube of Crane Break In Lube over the cam/buckets. Use mineral based 20W-50 for 500Kms, then change to 15W-50 (part or full synthetic). 5W-40 would be a poor choice. Edited January 18, 2007 by petert Share this post Link to post Share on other sites
Mandic 0 Posted January 18, 2007 Why 15W-50? Cheers Ziga Share this post Link to post Share on other sites
matty_gti 20 Posted January 18, 2007 Updating to the 26T sprocket from a 2L (and 52T chain) is more important that upping the pressure. Spinning the pump faster will improve low rpm pressure. Pour a tube of Crane Break In Lube over the cam/buckets. Use mineral based 20W-50 for 500Kms, then change to 15W-50 (part or full synthetic). 5W-40 would be a poor choice. 'Crane break?', how about just taking off the cam cover and poring oil on top of the buckets and cam, will that not do the job? And should i use lube for the new mains and big ends or can i just add loads of oil? And isnt 20w-50 to thick for a new engine?....shoudnt it be 10w or even 15w?...and is mineral differnt from part/full syn? ThAnKs Share this post Link to post Share on other sites
petert 601 Posted January 18, 2007 Why 15W-50? Cheers Ziga So it's heavier when it's hot. Share this post Link to post Share on other sites
matty_gti 20 Posted January 18, 2007 So it's heavier when it's hot. Dont you mean it would be 'thinner' than say 15w-40 when hot?.....what makes it heavier? Share this post Link to post Share on other sites
Banjo 1 Posted January 18, 2007 I think you should do some reading up on oil mate.. Share this post Link to post Share on other sites
matty_gti 20 Posted January 18, 2007 I think you should do some reading up on oil mate.. Ive read ,read.....and read some more...theres stack loads of info on oil..i think im jus gonna stick to castrol GTX 10w-40 for running it and then swap to somthing better after a few thou. Share this post Link to post Share on other sites
Banjo 1 Posted January 19, 2007 As long as its not synthetic it will be fine for running in, remember lots of full throttle once its warmed up and keep the revs moving all the time, that way you'll get a good seal with the new rings. Share this post Link to post Share on other sites
