joni
Crankcase Breather Pipe (main Oil Filler Pipe)
joni
Can anybody suggest a cheaper option than the stealer quoted price of £50 for this part? Does anybody else stock them or am i just going to have to put up with the old one or take out a mortgage for one from peugeot?
dd_156ar
I got one from the local scrappies. I think it was from a 405 as a lot of the PSA engines share the same pipe - cost £2 I think...
Guest MiamiBlueOli
I would suggest trying a scrappy or Autofive, GSF or another similar online spares place? Anywhere would be cheaper than Peugeot
Peugeot only and to my knowledge only a Peugeot part due to the low number's of these engines made, Not even the 8v one has had a pattern pipe made.
The only other pipe that may fit is the 8v 405, Just a idea so maybe completly wrong here
inferno
ive noticed a lot of wanteds on this breather pipe... would it not be possible for somebody to sort out a group buy on breathers? maybe samco style but obviously oil resistant... just a thought as i could do with one too... unless citroen have mine in stock sooner!
I could look into this as I have a supplier of these pipes, Need a min order of £200.00 thou
Guest ashnicholls
I am interested in an uprated set, as the quality of the standard ones is crap, and they look crap.
inferno
yes.. defo intrested in the main or a set miles... will keep an eye out for a group buy :P
stutto
Is this the pipe that runs from the top of the oil filler to the right of the oil filter?
If so I could do with one too.
richsmells
Mine's starting to perish around the jubilee clip. Would be interested!
Guest rick03054
Miles, you have your answer! :)
I'm interested too.
V8Pete
I'm interested too.
A price including freight to NZ would be wonderful :D
The dealers want the equivalent of about 150 GBP for them here. I tried making a cheap(er) replacement up with brass hose fittings and a T-joint, but it was too bulky and the hose wouldn't bend enough.
