acox99
What Engine Mounts?
acox99
I was looking at getting solid engine mounts, found a solid lower mount, but can you get solid top mounts as well? or are Group N rubber top mounts ok? its for a sprint car. what is everyone using?
boombang
The BBM stuff is hard enough for any use - Grp N spec all round with uprated lower mount.
hengti
can you actually get solid mounts?
wouldn't have thought they'd be a good idea, even in a compo car - you'd just break things - ?
boombang
I've seen a solid ally lower mount - in car it honestly felt the same as a BBM lower but they aren't usually made solid for a reason - to give a slight cushioning effect.
BTW I think the guy made it up on a lathe rather than buying it!
Rippthrough
There are 2 bushes in the lower mount though, so the other should provide some cushioning effect.
boombang
yeah that'd true. Looked pretty hardcore though but as I said it was really no worse than "grp A" spec.
Jonmurgie
I believe Stew does 2 versions of the bottom mount, one similar to the PugSport GrpN and one a little stiffer (which is what I now have) :)
acox99
spoke to stew this morning, and thats what he is sending me.
