westy
Knackered Rear Beam?
westy
morning,
Recently the rear end of my '90 1.6 has started creaking like hell - whenever I reverse down my drive (its on a hill) whenever I get in the car etc etc
However, there's not a single bit of camber on the rear wheels. Could my beam be knackered?
Cheers :wacko:
Yes, just because there isn't any signs of camber doesn't mean the beam is Ok.
Try pushing on the hatch & see if it coincides with you doing this, you might find that one side of the beam is starting to seize. Also try jacking the rear of the car & looks for the arms dropping the same amount.
Graham.
westy
Cheers for moving the thread :wacko:
Tried pushing on the back, there's no creaking at all.
Try adjusting the boot rubber stops, if it is just resting on the lock plate it will make lots of noise.
Graham.
westy
I'm not the most mechanically minded, how would I go about adjusting these?
Ren
Open the tailgate and you will see a rubber bumpstop on each side, just unscrew them slightly to wind them out and stop it rubbing.
HTH.
Ren.
westy
right, tried adjusting the bump stops, nothing's changed. It creaks when you push down on the back of the car with the boot open..
ideas?
bitchass 205
erm, can't answer your problem but my rear beam creaks like hell when ever i get out and have parked on a hill, i try not to use the handbrake because sometimes it sticks. However if i push down on it it doesn't creak at all.
Alas, the rear beam is fecked though, bad camber and scrubbing on nearside :lol:
