Guest justinhincks87
Engine Rebuild!
Hi there if i was to get a 205 gti 1.6 and pull the engine out and rebuild all the bottom and top end, new rings, bearings, seals would the engine be as powerfull as it was brand new which is 115bhp??
arry
Probably not.
Don't forget ancillaries like injectors, fuel pump, air flow meter etc - are 15 year old injectors still going to have the flow rate they had when they were new?
brianthemagical
would the above have much benefit? any recomendations of how to get the origional power using standard components? my cars been RRed at 110 hp, it's a 1.9 non-cat. thanks
arry
Compression test it - if it's low on compression that'll hinder power. New rings, sort the valve seats will help.
boombang
A clean + refurb of the injectors could be worthwhile, along with re-tracking of AFM, service/rebuild of dizzy, making sure you have an OE spec downpipe + exhaust (or Magnex), new air filter, followed by a rolling road session.
A few things can be done whilst the head is being refurbed such as 3 angle valve seats and a light skim/decking of the block to raise compression a little. I'm no expert on these engines though but generally those help a bit!
is 110bhp good for a 1.9. arnt they 122 bhp?
brianthemagical
exactly, and i think it's 128 bhp.
what do you seriously rekon the 1.6 would be to 60 nowadays then??
arry
Slow. Even 1.8 mondeo's will out accelerate it
no that cant be true. a mondeo 1.8 gets to 60 in 10.6 seconds. come on taht cant be true, i thought people called these GTIs Pocket rockets
unfortunately very true
but i must have a good 1.9, as it can keep up with a clio 172...
(its bog standard but recently reconned and had a lot of work on the management)
i think that is real bollox. the 205 should skin it off the mark, im sure the mondeo would overtake after about 60 or 70. why the f*** are people saying that they beat vtrs if they cant beat a f***in mondeo 1.8!
brianthemagical
i think this thread has lost sight of the appeal of a 205, it's the corners where it shines. it would be able to muller a mondeo round a track/ point to point.
jonah
You shouldn't need to do any of that IMO. My 1.6 is on well over 100k miles (120k indicated but has been clocked at some point), the bottom end has never been touched, original cam, valves, dizzy, injectors etc., and still makes every bit of power that it did when new according a to well-respected rolling road. Certainly feels lively enough to drive!
That depends on your thinking & which rr it was done at. 110nhp at the wheels should be a good one imo.
The 1.9 often only makes a few bhp more than a similar 1.6, most 1.6's seem to make the book figure where the 1.9's don't but later cat equipped ones seem better at having near the book power. The 1.9 is more about the mid range though.
Most are 128bhp but CAT equipped cars are booked at 122bhp.
Graham.
ye 110 bhp at the wheels is good. becuase on the books they say the bhp as from the flywheel dont they? :wacko: I need to sell my car to get a GTI!!
brianthemagical
it's 87 bhp at the wheels, 111.6 bhp at the fly wheel. it's the d6b, xu9ja engine. it is 15 years old so some loss has to be expected. it just increases the anticipation of the full power.
