jimbean
French Pistons
jimbean
heres a good one!
building a xu engine... the piston top has a word "dist" and a arrow
what does it mean? and which way round does it go?
i know this is a question that i have had many times, with many people, i do know the answer to the direction but do not know the meaning of the word
thought i would post it as the answer it is not as straight cut as it seems.
huxley309
Many people mistake dist for meaning that the piston has to face the distributor, when in fact it faces the camshast verniers, many engines have been built wrong because of this mistake in the past
Dist in french might be short for cam, not sure now
Hope this helps
dist = distributeur de tension (I think...) which is French for timing belt.
jimbean
thought it was some french word
i wonder how many readers or shouting doh!!!!
Rom
Does it actually cause any problems if built the wrong way round ?
jimbean
[only if you have a heavy skim and a miss a gear...
thats how we found out abut the myth
It's not so important with Flat top piston's, It's the 1.9 psitons that are a issue, It doesn't help combustion, I remember Matt C doing this with his turbo engine and he was down a little on power
Guest rick03054
Would it not mess up your squish area completely as the flat part of the piston would be on the wrong side of the cylinder?
Edited by rick03054
PumaRacing
Yes.
The bit no one has mentioned though, probably because no one knows about it, is the gudgeon pin offset. Gudgeon pins are not central in the piston. They are a little bit to one side and that offset wants to be on the correct side of the engine.
Gavin Waddell
dist = courroie de DISTribution, translated into english = cambelt. :P
Beastie
Yes.
LOL - it helps when you know what you are talking about :P For those without that knowlege (whatever the subject) there's a good alternative rule of thumb in my experience: A manufacturer the size of Peugeot doesn't go to all the trouble of marking the way something goes if it doesn't make any difference. Therefore always assume that it's important.
