typefern
Hub Nut Torque
typefern
Hi
First post so hello to everyone
Could any one help with the torque figure for a 205 GTi 1.9 G reg hub nut.
Cheers in advance
John
p.s. tried search engine, no luck
Guest yaztromo
Hi
Cheers in advance
John
Just tighten it up really tight with a breaker bar. It doesn't matter so much. Never checked the figure myself and had hub nuts on and off loads of times.
I would only worry about torque settings when it comes to the head bolts.
Edited by yaztromo
typefern
Cheers for the quick feed back
As much aas Id love to just tighten it to F.T. I'm a Land Rover Fitter and its just not how I work, I agree other fixes like drop links you can guesstermate how tight. I just wanted the exact figure just to be sure.
For instance Range Rover hub nuts are 400Nm, no way can you get that figure on a breaker bar.
Sorry when on a bit, cheers for the info.
John
Simes
My torque wrench only goes to 150Nm so I tighten the nut to that. Then I stick a bit of scaff pole onto a breaker bar and give it a final quarter turn.
the wheel bearing is sealed so the torque of the hubnut doesnt adjust it or anything. FT really is all it needs to be IMO.
TEKNOPUG
I couldn't get mine upto the specified torque even by jumping on a breaker bar and a length of scaffolding!
Guest RickGTIBaker
Fit nut, tighten as mush in crouched position, fit breaker bar, turn wheel so bar protrudes out, chock wheel, stand on bar, bounce on bar, ask the Fat Neighbour to do the same, one final bounce.
Fitted.
Never had 1 fall off.
I've seen Land Rover wheels fall off in front of me before, was that your handy work? :blink:
inferno
well i do both hub nuts up FT, and head bolts up until they feel tight enough... whats a tourque wrench? if i had one of those id smash my car up so much more... :blink:
as said above pug bearings are non adjustable, unlike some tappered ones that need specific measurements ... or just FT - 1/4 turn normally!
Guest rick03054
You've mentioned that before inferno, and if it works fair play I'm in no position to contest it. But as a matter of curiosity next time you do it could you then stick a torque wrench on it and see what reading you get? Just to see how close 'a couple of elbow clicks' is to the book value.
There are a lot of skilled people who do their trade through feel and I've often wondered how close they come to the technical methods.
pugrallye
its is actually possible, but only if your doing a specified torque over and over for example if you fit wheel nuts for a living, lol
There is no substitute for a torque wrench though, as if its calibrated, there is no disputing it
Also someone managed to strip the thread from the hubs through doing wheel nuts to FT
Edited by pugrallye
