Guest TSL 333 Posted September 3, 2006 Just fitted ny new radiator which was alot easier than what I had anticipated. All bolts were seriosuly seized at 18 years old so I replaced them all. Car is now running sweetly and there are no leaks. That said, I could not re-attach the top radiator clips and as a result, the radiator seems a little loose at the top, as if nothing is really restraining it. How do these clips go on? I did not really pay much attention to the removal. The clips were not removed from the cooling fan section at all when I removed the radiator. A photo would be ideal. Thanks in advance. Share this post Link to post Share on other sites
pug309twin40s 1 Posted September 3, 2006 the top clips lift up and sit in the slot along the top of the radiator to stop the radiator moving. there should be a black rubber piece that sits in the groove on the radiator then the spring sits on this. Share this post Link to post Share on other sites
Guest TSL 333 Posted September 3, 2006 the top clips lift up and sit in the slot along the top of the radiator to stop the radiator moving. there should be a black rubber piece that sits in the groove on the radiator then the spring sits on this. Ahhhhhhhhhh, so I am mising the back rubber bits!!! Scrappy I think!! Unless anyone has some spare that I could buy........ Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted September 3, 2006 Have you not got your old radiator still? They should be in the top of it. Graham. Share this post Link to post Share on other sites
Guest TSL 333 Posted September 3, 2006 Have you not got your old radiator still? They should be in the top of it. Graham. Graham, I already checked - nothing there!! Anyone got any? Share this post Link to post Share on other sites
Guest TSL 333 Posted September 10, 2006 Got them yesterday from a scrappy togther with a front scoosher motor for £3.00!! The newer base models (of which there were a few in the scrapy) appear to be different but I eventually found a GTI!!! Share this post Link to post Share on other sites
