t16ryan
1.6 Gti Using 1.9 Driveshafts?
t16ryan
to fit 1900 shafts to a 1600 shell, is all thats needed to swap the complete hubs? As have 1900 hubs complete with shocks and springs and i have shafts or is anything else different?
Jonmurgie
Nope, just swapping the hubs complete with driveshafts will do the job fine :)
Henry Yorke
But your 1.6 brakes won't fit onto 1.9 hubs unless you swop discs IIRC as the caliper mount points are different
t16ryan
Cheers nice one, :)
GLPoomobile
Are you sure?
I have fitted my 1.9 calipers to my 1.6, so it should work the other way around shouldn't it? I've had to keep the 1.6 discs, and can't fit the 1.9 discs until I get the 1.9 hubs and shafts on there.
Calipers will fit fine, but you'll need 1.9 disks as the offset will be wrong on the 1.6 ones :)
Revla
To steal for a mo....
I'm running 1.6 setup, can I use 1.9 calipers/ discs & pads on the 1.6 hubs or should I change to
the 309 GTi hubs I have? Don't really want to use the 309 d/s and wishbones really.....
I know this has been covered previously, but can't find it!
Mainly changing due to the 1.6 slider issues - as they always seem to have!
Trev
Revla
Trev
Bump.....
Can anyone point me to the correct post on this please?
Just swap the calipers over to 1.9 ones - retaining the exisitng 1.6 disks, hubs, and driveshafts - and all your problems will be solved <_<
309 GTi hubs are identical to 1.9 GTi ones, so you could use them together with 1.9 driveshafts on your existing wishbones - you'd also need 1.9 disks for this setup.
Revla
Just swap the calipers over to 1.9 ones - retaining the exisitng 1.6 disks, hubs, and driveshafts - and all your problems will be solved :lol:
Cheers pal - much appreciated!
VisaGTi16v
Old thread alert sorry!
I just bought some 1.9 calipers to replace my 1.6 ones retaining the 1.6 discs, pads and hubs for now. They didnt come with the 1.9 bolts however and I believe that I need to use them when fitting 1.9 calipers to 1.6 hubs.
So the question is, are the 1.9 bolts longer or shorter than 1.6 ones, I am hoping shorter then I can cut down some spare 1.6 ones (if so how long exactly in mm?), if not I will have to buy some suitable ones or put a wanted listing up
cheers
Edited by VisaGTi16v
Considerably shorter - probably about 35mm long off the top of my head.
VisaGTi16v
Excellent thanks. Would be handy if someone had one laying around that they could measure the thread length on so I dont have to cut mine more than once :D
03 4405 17 04 CALIPER SCREW 12X1,50-35
I've got one here from a 406 thats the same size etc as the 1.9 GTi ones; overall length from underneath the head is 35mm (inc head 45mm) with a shouldered part thats 15mm long.
VisaGTi16v
Cheers for that
