roland rat
De Catting A 205gti
roland rat
ive got a full magnex system for my 205 gti to fit and after the centre box started to blow i feel nows the right time to put it on the car.the only issue i have is how will removing the cat affect my car?will it run lean/rich as the lamaba sensor is not fitted?any other possible gremlins that could turn up due to me fitting the exhaust? :(
thanks ashley
youll need that lambda sensor fitted for it to run properly, plus you'll fail the MOT...
roland rat
mots months away ill worry about that another time :D;) .if i dont fit the sensor how will the car run? :( (no place on the magnex manifold to fit it to!)
get a boss (read suitably sized steel nut) drill a hole and weld it on, job jobbed.
roland rat
that sounds like too much hard work!!! :( only joking.thanks for the info mate ;)
sherly
  roland rat said:
mots months away ill worry about that another time :D:D .if i dont fit the sensor how will the car run? :P (no place on the magnex manifold to fit it to!)
How old is the car? I decatted mine and it's passed every MOT since (4 years) - on a Dec92 K reg.
I also had a full magnex exhaust fitted at one point - I managed to fit a stainless lambda boss onto the manifold (on the collector section I recall). It is very tight for space but it fitted.
Once I had drilled the hole and pushed the boss into place I got a local fabricator to TIG weld it in position.
Mart :)
roland rat
Mart :(
its on an l-reg aug 93'.i might look into buying a 'sports' cat and mix it with the magnex system and manifold.how close is your 205 on the emmisions test? :lol:
