DaveK
Changing Timing Belt First Time
DaveK
Is it a wise idea to change the timing belt myself although i have never done one before? Its not on a 205 but on a vectra diesel so there seems to be plenty space compared to the 205.
Dont fancy doing it wrong and knackering the engine but would save me £100 most likely.
I have a haynes which i could follow but what do other ppl think?
Dave
jonah
Everyone's gotta start somewhere :ph34r: No reason to think you'll knacker the engine if you work carefully.
Don't know if modern Vauxhall diesels are the same but on the old OHC 8v engines the cambelt tension adjustment was done by rotating the water pump... which was usually impossible (at least not without breaking the coolant seal). If your engine has a separate belt tensioner you should be fine.
Jonmurgie
If you've got loads of space then give it a go... there's nothing special about it just be extra careful not to TURN ANYTHING when the belt is off!!
kyepan
try and make or use some locking pins, some people use drill bits, but others make or buy them, that will keep things in place whilst the belt is off.
Guest BrainFluid
You might be lucky and find out that the vectra has locking holes in the side of the cam sprocket and the fuel pumps sprocket like the Pug XUD engines have, which make it a doddle (as long as you remember to take them out before starting the engine, lol )
