Edp
Magnex Exhaust
Edp
Anyone had any problems with the centre box hitting the rear footwells underneath?
Mine basically sits on it and vibrates through the car. It also hits things when driving like steep humps and driveways. The cars only lowered 25mm?! I'm using a standard downpipe and its fitted to an Mi with the manifold welded at the correct angle.
Just wondered if anyone has any tips? Is it just a case of trail and error....
kyepan
Perhaps some longer exhaust rubbers would mount it slightly lower.. although that may mean it hits more stuff on the ground.
ORB
You could bring it up as close as possible to the footwells as you can, but put a strip of rubber inbetween to the Zorst and the floorpan (although this is just plain bodging)
Mongo
Its a case of trial and error, it originally done it when i had it fitted with manifold, i got it re-fitted shortly after and it was fine for a while. Started doing it again,, then once i had it sorted it was fine for 2 years.
Alastairh
Presume you have a stiffer bottom engine mount?
huxley309
a stiffer lower mount is essential as magnex at least recomended it themselves
scorpions have the same issue, best way is to take the centre mount under the car, heat him up with an oxy acetalene torch and bend it downwards this will make the rubber mount want to keep it away from the floor of the car
a fiver at your local kwikfit should sort it out easily enough
Edited by huxley309
