Guest Dave_the_B Posted August 26, 2006 Hello everyone, I've been lurking on here since i bought a cheap/almost knacked 1.6 gti for track days a couple of months ago. First thing to do is thank everyone on here for all the information I have gleened from using the search facility....THANK YOU Now I must berate you all for getting me completely hooked on 205's....damn you all If it wasn't for this forum I wouldn't have managed to swap my little 1.6 engine for the lovely 1.9 I now have nestling in my engine bay. When the engine was out I cleaned and tightened up all the gear linkages, made sure everything was nice and loose and not binding on anything. I took off the 1.9 gearbox and replaced it with the original 1.6 one, the only difference I could see was the design of the 1.9 flywheel was different, apart from that I bolted it all together and put it in. Now the gear change is stiff as a stiff thing in Stiff-land, I've checked the linkage and all seems fine, it seems to be the gearbox has stiffened up Any thooughts on this would be appreciated Many thanks Dave Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted August 26, 2006 Sounds like you have over tightened the large 22mm bolt on the L bracket. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted August 28, 2006 First thing to do is thank everyone on here for all the information I have gleened from using the search facility....THANK YOU AMEN . Share this post Link to post Share on other sites
Guest Dave_the_B Posted August 29, 2006 Sounds like you have over tightened the large 22mm bolt on the L bracket. Yep done it up too tight Thank you Thank you.......again Dave Share this post Link to post Share on other sites
