Woosey
Fan Intake Under Scuttle Panel.
Woosey
took my scuttle panel off, there is no standing water in there, however there are holes in the scuttle panel to allow water straight into the fan intake....how on earth is that good design! :D
So how can it be "patched" up so water hasn't got an easy ride in? make a snorkel for it?!
thanks
Chris
Edited by Woosey
Jonmurgie
what ARE you on about?! It's clearly not a problem so go find something else to fix!!
Woosey
It was last on my list :D
Soaking wet passenger side isn't where its at :)
Edited by Woosey
TEKNOPUG
How an earth else is air going to get into the fan intake without holes in the scuttle panel?????
You're soaking passenger side will either be a leak in the heater matrix of the water will be coming in through the window rubbers
Jonmurgie
Do you have a sunroof? If so then it's probably a blocked drain pipe from there...
Woosey
Yup
however the leak is under the carpet
TEKNOPUG
Heater matrix then. Or you have a hole in the floor!
Woosey
im 100% its not the heater matrix, ive had one go before!
she hasn't been driven in 8 months and the coolant hasn't gone down, also rules out a hole on the underside.
mystery leak!
Jonmurgie
How do you know it's under the carpet and not on top? I get a leak in my track car from the door seal rubber and where it joins on the bottom... might be worth looking there?!
Woosey
top carpet = always been dry
when i pulled it out to stick the alarm in ages ago, it was wet underneath, dried it up, however its back to how it used to be!
Gentrix
The scuttle panel has to be fitted underneath the Windscreensealing - if it just sits on top of the sealing, you will get wet feet. So check, if the scuttle panel is correctly fitted
andi
Woosey
andi
ah ok didnt do that today!! thanks!
