WooDooUK
Spot Lamp Brackets
WooDooUK
Hello, i have a set of 4 Super Oscars and am looking to mount then using the Brackets that demon tweeks sell.
Anyone know where these mount the car? (Bumper, bodywork etc.)
Cheers,
Craigb
I have a pair of DT brackets , they pick up on the bumper mounting and the bumper itself.
I doubt that there is enough room to mount 4 lamps though.
WooDooUK
Cheers for the info.
umm.. thats a bummer i didn't realy want to start drilling holes in my bumper,
Should be ok with for lamps,
This is what the DT web site says.
Tailored steel lamp brackets. Duplex design allows mounting of four lamps; two up - two down. Tough, durable black coated finish.
neil88
You can fit the 4 lamps on but the bottom ones will be quite low,
also you can use the mounting holes already in the bumper but the spots will be quite close 2 the head lights
Craigb
I have actually bolted a piece of box section linking the two brackets , so that i can postion mine any where i want .
This idea may assist
Also serves as additional protection for the rad , when you have the inevitable off...
rogerrally
Buy a spare bonnet, and fit up a glass fiber pod, to keep your lamps safley up on high ( keeps vents free), only fit on for an evening blast down the lanes!
Youll need relays for power distro
