Woosey 0 Posted August 19, 2006 (edited) Im really baffled, water appears in the passenger side only, under the carpet and pools in teh bottom right, its not the door seal, and its not the heater matrix..... any other ideas where this water is coming from? thanks chris Edited August 19, 2006 by Woosey Share this post Link to post Share on other sites
GLPoomobile 958 Posted August 19, 2006 Im really baffled, water appears in teh passenger side only, under the carpet and pools in teh bottom right, its not the door seal, and its not the heater matrix..... any other ideas where this water is coming from? thanks chris It might be the collective tears from all the members who are about to cry 'DO A SEARCH'! Seriously, this has been discussed recently, at least once. Share this post Link to post Share on other sites
Woosey 0 Posted August 19, 2006 It might be the collective tears from all the members who are about to cry 'DO A SEARCH'! Seriously, this has been discussed recently, at least once. At sorry, ill give it a whirl thanks mate Share this post Link to post Share on other sites
d-9 0 Posted August 19, 2006 What GLpoomobile was trying to say was "I know the answer but I'm not going to tell you nah nah " Windscreen seal is the most likely culprit, if its damp at the front of the passenger footwell. Share this post Link to post Share on other sites
Paintguy 0 Posted August 19, 2006 I found 2 areas on mine that were letting water in; one was the windscreen seal, and the other was water running inside the door, and out through the gap between it and the inner trim panel. Plenty of bodyline to seal up the door holes sorted the latter Share this post Link to post Share on other sites
