Owain1602
Starting Omex + Dcoes
Owain1602
I have finaly got a few minutes the other day to look at my rally project running omex mapped ignition and 40dcoes.
I am using a 36-1 trigger wheel, got it mounted as close as i can to the timing position but obviouslt it will be a bit out. I think next i need to set the offset values with the "spark out" to finalise the trigger wheel position but in order to do this i need a fairly steady idle or low speed. Basicall what i would like to know is, what you guys recon i should set the advance to on the map so it will run to about 2-2.5k revs? Say set them all to
10deg advance or what, and a suitable cranking advance, i have it at 5 now.
I got it started the other day just to see if it would and it did but on cranking it seems to spit back a bit and it has sooted up new plugs in about 3-4 minutes, i think its cos the timing is way retarded cos i just set the idle mixture to a basic 2 1/2 turns out.
Any advice or tips from you with more experience than me on this subject? Thanks a lot,
paul wicks
Give Neal at Des Developments a ring if you get really stuck. He added Omex ignition only ECU to my 205 Mi16 on twin 45 DHLA Dellorto carbs.
http://www.des-developments.com/
Owain1602
great thanks, do you think he will mind? ill have a look myself first.
Jakob
You need to have more than 5 degrees. This OMEX 500 (ignition + fuel) map is based on following:
Omex 500
N/A Engine
Load = TPS / Load 100 = full throttle
RPM 0-8000
300ml nozzles
36:1 trigger wheel
The ignition map should give you a fairly good starting point.
If it has any interest you can download the full map here on my website: http://www.powerpage.dk/tuning_motorstyrin...meksempler.aspx
It is the last download "Program 3"
/Jakob
Edited by Jakob
Jakob
The CPS (triggerwheel) settings is based on a magnetic sensor placed 90° before TDC
/Jakob
Owain1602
thanks a lot
