smckeown
Need To Power A Cigarett Lighter Electrical Item...
smckeown
Received jon's g-tech pro meter, but i assumed it was battery operated. Can i somehow hook it up to some temporary wiring in my car ?
smckeown
or can you buy a female end to wire up yourself ?
willxs
if you want to keep it in the car, could you not wire it up with a switch? take a main feed put it through a switch and just turn it on an off when you wanted?
shouldnt think it would be to much trouble.
-edit, just seen the tempory bit.
Edited by willxs
pugpete1108
i am sure you can buy female sockets to wire in , but why not just nip to the local scrappy and take one out of another motor for now just cable tie it to something and run it to a positive supply
smckeown
yeah i was just thinking the same while watching dragons den :)
Edd-XS
If your local halfords boys are friendly enough, they may let you have a female cigarette socket from their hardwire kit. If not let me know and ill grab you one for nowt :)
Edd
sorr
You can buy an extension kit from Maplin for a few pounds. Just chop of the male end and you have a wired up female connector ready to connect to the cars power supply.
mi16nut
As said, only a quid or so from Maplin. I fitted one behind & underneath the head unit area for my Roadangel. Just need to find a switched positive & earth to branch into.
Mark.
