roland rat 11 Posted August 7, 2006 ive got a 307 hdi set up to be fitted to my car and was going to do it this weekend but ive been offered a set of 14;; compomotives and im sure reading on the forum that the 307hdi setup doesnt fit under 14' alloys .does anybody know the biggest set up i can run using 14'' alloys? thanks ashley Share this post Link to post Share on other sites
Butler 0 Posted August 8, 2006 You can fit 266m brakes under 14" steelies. Not sure if the 307 hdi is 266 or 283mm. 283mm won't fit under any 14 wheels. Share this post Link to post Share on other sites
Ren 0 Posted August 8, 2006 307 hdi brakes only just fit up 15" speedlines with a couple of mm to spare so I wouldn't think you could fit them under any 14's Share this post Link to post Share on other sites
Rippthrough 98 Posted August 8, 2006 (edited) the 1.4 hdi is 266mm I think, which should just fit? Depends if yours are from a 1.4 though. -Phillip Edited August 8, 2006 by Rippthrough Share this post Link to post Share on other sites
sonofsam 5 Posted August 8, 2006 Mo's are well known for their brake clearance giving capabilities. Share this post Link to post Share on other sites
TVH 0 Posted August 9, 2006 Mo's are well known for their brake clearance giving capabilities. I have 15" ET15 MO's and 283mm discs, wilwood midilite 4-pots and the clearance between the rim and the caliper is about an inch. I'd say 14" MO's would fit easily over these brakes. Share this post Link to post Share on other sites
