acox99
Gri Beams Same As Gti
acox99
found a 309 gri, has gti engine, are front wishbones and rear beam same as gti, even though gri has drum brakes at the rear.
Everything is different, The GRI uses the base model suspension front and back, Thou you can use the beam if you find some GTi Torsion and Anti roll bar.
The drums are as the 205 1.6 GTi with normal slave cylinders no compensator slave cylinders.
Jer309GTi
Miles, I had a 1990 GRi and that had GTi front suspension with solid discs and 1.6 GTi drums @ rear. Not too sure on the beam, I never had it apart to check the diameter of the TBs or ARBs
Definately thinner torsion and anti-roll bars, plus the different brakes.
