Guest twinbridge01
Mi16 Fuel Pump
Guest twinbridge01
Can anyone help!!
I have finally finished wiring my 1991 205 gti up to a 1991 mi16 engine. I have used AndyRs guide and everything went straight forward enough.
The engine will now turn over but I am not getting any power to the fuel pump. The fuel pump relay does not switch when the engine is turned over either. I thought this might be the problem so I fitted a new one but no joy.
Does anyone have any suggestions??
Are you getting a switching signal to the relay when cranking? if not trace this back as it could be the Power feed or the signal from the ECU
Guest twinbridge01
Im not getting a signal to the fuel pump relay when cranking. I ll trace it back this weekend and see if im getting a 12v supply when cranking. Ill test it on the original side of the 205 loom.
If this is ok I will swap the ecu with a spare to see if that cures it. Have you heard of anyone else having problems like this with the ECU??
Thanks for the info.
Chris
Could be the ECU as this switch's the pump on & Off, never seen it before but there's always a first
jonand
Chris
I had this problem a while back - but check the crank sensor first, because if the ecu isn't getting a signal it won't know the engines turning and consequently wont energise the pump relay.
Jon
Guest twinbridge01
Jon
Thanks Jon
Thats a good point that I havent checked.
