pee vee
205 Pulling On Accleration
pee vee
hi guys
Anyone got an idea of what might be wrong with the car,
symptoms being
If you boot the car quickly it Tugs to the left for a second,
then if you lift off it tugs to the right, again just for a moment.
could it be gearbox mount??
any help appreciated thanks!! :ph34r:
EDIT: SORRY JUST REALISED THIS IS POSTED IN THE WRONG SECTION!! apologies!!
Edited by pee vee
travill
check you wishbones for play
pee vee
thanks mate!
just noticed someone else has started this exact topic in
the other forum!
DOH!! i'll learn to use search button! lol
JayCC
  pee vee said:
thanks mate!
the other forum!
I had this, it's going to be the passenger side wisebone bush, probably the front one.
Jack the car up and grab the wheel. Try moving the wheel in every direction and check for play in the wishbone.
Took me about 1-2 hours to replace (1st time i had done one) and £45 for the part.
boombang
£45!!!
Brand new full set of wishbones and bolts is under £20 from Peugeot!
maxi
  boombang said:
£45!!!
Where the hell is your main dealer?????? Pug Parts manager lives 2 doors down and with my discount the wishbones complete with bolts are a LOT more than that.
I always run pattern ones and replace them roughly every 3 years.
Maxi
pee vee
thanks guys! seems like a easy fix then!
:lol:
  boombang said:
£45!!!
you mean wishbone BUSHES and bolts surely?
boombang
Indeed I do :s
aldo56
thank god its just the bushes, i just bought a new arm to solve the exact same problem for £45 for non-pug parts!!!
phew! :(
Guest 205_dave
Check for play in the hub/balljoint aswell. I had the same problem as you even after fitting polybushes, the hole in the hub that the balljoint pin goes into had ovalled out!
