ste996
Seats
ste996
What side of the drivers seat is the tilt adjuster, Left into car or right towrds the door. It's a s2 1.9 gti.
The reason i ask is i think my drivers seat is a passenger one bolted to the drivers subframe.
:wacko:
roland rat
:wacko:
its the side nearest the door.so on the left hand side for passenger seat and on the right hand side on the drivers seat
hth
ashley
ste996
My passenger seat is wrong then, The adjuster is nearest the driver seat. still got one wrong seat then.
GLPoomobile
Depends if you mean the handle to flip the seat forward or the knob to adjust the angle that the seat back reclines at.
The flip handle lays outbourd on each side, nearest the door. The adjustment knob lays inboard, towards the handbrake.
ste996
I meant the adjuster knob to tilt it back.
Have been looking at some pics and you have now confirmed it. My drivers seat is a passenger one the tilt adjuster is toward the door not the handbrake. wondered why the plastic trim on the new subframe looked like it would not fit.
New drivers seat required anyone got one then in good nick red/black
TEKNOPUG
No, no, no.
It's very common for passenger seats to be swapped over to the drivers as the drivers seat obviuosly wears a lot more than the passenger one, particularly the bolsters.
Is it really worth the hassle and expense of trying to find a good condition drivers seat? You can always swap the frames over. It only becomes a slight problem if the seat release lever rubs against the tolt knob. But the lever can easily be bent to one side a little.
Spend your cash on making the car go faster, stop better!
ste996
"Spend your cash on making the car go faster, stop better!"
Work in progress :wacko:
GLPoomobile
As per Teknopug you can swap the frames. I did this and it is a ballache when you do your first seat. It does mean that rather than holding out for a good drivers seat you can get one functional drivers seat frame and one good passenger seat (should be plenty around) and just stick the good padding, bolsters and trim onto the drivers frame and ouila!
ste996
all good tips thanks.
From what i've learned so far, My drivers seat has already been swapped for a passengers one and fitted to the drivers subframe when i got the car.
Thats why the plastic side trim is missing(side of seat) and when looking at the replacement subframe will not fit then because the recline knob is on the wrong side.
Will take of this bit of trim, bolt seat to new frame and roberts your mothers brother, no more wobbly seat.
:D
steve@cornwall
always seems we should try and get together with our continental neighbours to swap seats!! with their driver's seats being our passenger's our good passenger seats should be worth loads to continental enthusiasts. Anyone live close enough to a ferry port ?
Paintguy
That's a very good idea, that I know Henry Yorke is looking in to :ph34r:
Edp
Ive just finished taking apart a good phase 2 cloth passenger seat and putting all the parts on a drivers frame.
I even reused the little metal clips which take ages to do using pliers. I'm really happy with the outcome.
I reinforced both bolsters with some carpet tape underneath the cloth too so that should last longer. I will give it a hoover and post some pictures.
Ed
