5150maxie 0 Posted August 4, 2006 my front drivers side is making squeeling noise on turning right so think wheel bearing is going.i know i will have to get it pressed out and in but does the spline piece for the drive shaft come out easy with out damage?or do you get one with the kit as ive not done a wheel bearing yet? Share this post Link to post Share on other sites
sonofsam 5 Posted August 4, 2006 The spline part you talk of is the hub wich sits in the bearings and the bearings seat ino the hub carrier. So yeh the hub should come out no probs on a press with no damage. Share this post Link to post Share on other sites
niklas 1 Posted August 4, 2006 The common problem is that the outer bearing part (race?) sits pretty tight to the hub.. Share this post Link to post Share on other sites
