wildejon
Driveshaft
wildejon
Is there any chance that replacing a driveshaft could affect the tracking?
Probably a stupid question but I need to get my tracking done and I don't want to have to redo it after I've replaced the driveshaft.
I'm assuming they are made to a tight tolerance and they will not have any effect but I'd be a dumb ass not to check first....
Thanks!
Guest 205_dave
Changing a driveshaft wont affect the tracking, as you disconnect the wishbone from the wheel hub to get the driveshaft out. Tracking is adjusted by the steering arm.
wildejon
Thats what I thought, cheers for confirming though mate.
Jon
saveloy
Actually, there is a chance that a d/shaft change will alter the tracking. Since it is possible to tighten the shaft to a different degree which alters the hub position slightly.
Guest 205_dave
The hub is held in place by the wishbone though, so the tightness of the driveshaft nut shouldnt alter the angle?
saveloy
In theory Dave you are right.
But the very fact that the driveshaft can be tightened to a different degree means that the hub can sit in a slightly different place.
niklas
The driveshaft is loose so to say, since the CV joints are not solid in any way. To allow suspension travel and steering the CV joints can be compressed and extended to a certain amount.
The suspension leg, wishbone and steering arm are alone resonponsible for keeping the hub in a solid position and keeping the tracking in its position.
wildejon
Good point, like it, cheers!! :P
