PugAddict 0 Posted July 31, 2006 Picked the car up a couple of months ago and it had been sat in a field for a year!! It's running quite well but is it worth putting a dose of Redex Petrol Injection cleaner in? Cheers D Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted July 31, 2006 If it makes you feel better, never seen it make any difference though. Share this post Link to post Share on other sites
aeinstein 0 Posted July 31, 2006 Picked the car up a couple of months ago and it had been sat in a field for a year!! It's running quite well but is it worth putting a dose of Redex Petrol Injection cleaner in? Cheers D did mine with redex a while ago, whilst servicing it, and it felt livelier after, but i think its the fact i changed the fuel filter at the time. it did smoke like a bitch as it ran through, so if thats it cleaning the engine then it must of done some good. wouldn't of said that rolling roading it would notice much difference. al Share this post Link to post Share on other sites
saveloy 8 Posted July 31, 2006 If it starts and runs OK,then it doesn't really need a thing. Injectors have a habit of sticking if they are left unused for long periods. You will have seen an adverse affect by now. If you are going to us an injector cleaner,get hold of a bottle of Redline injector cleaner. It does work and it has manufacturer recommendations. Alternatively,go to a BMW garage and pick up a bottle there. Either by name or BMW branded bottle. Share this post Link to post Share on other sites
Gregg 0 Posted July 31, 2006 Decent fuel can have just the same effect, Shell Optimax has plenty of cleaning agents in it. Only way to get injectors properly clean is by taking them off the car and having them done ultrasonicly (ASNU machine), not that expensive if you can remove them yourself, probably around £50. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted August 1, 2006 Which is what I'd do. Cleaning the injectors is worth while from my experience with two 1.9 engines but never really noticed any difference from a bottle of redex... Share this post Link to post Share on other sites
PugAddict 0 Posted August 1, 2006 Cheers for the replies I run optimax wherever possible, so I think I'll just leave it be for the time being Share this post Link to post Share on other sites
mattmk1 0 Posted August 1, 2006 Thats another point, does anybody see any benefit of running optimax/ultimate. It made absolutely no difference to my old 1.6 engine, except it just drank it faster. So far ive never been bothered to put optimax in the 1.9, as it just seemed a complete waste in the 1.6! Share this post Link to post Share on other sites
DaveW 6 Posted August 1, 2006 indeed it does matt as 1.9s are ment to be run on 97/98 ron fuel. theres a few topics about it. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted August 1, 2006 Unless you adjust the ignition timing to suit then it is a complete waste. From what I'm told the 1.6 runs well on 95 RON but generally you will find quite a bit more power from a 1.9 running on 98 versus one set-up for 95. However, this will not just happen, you have to aadjust the ignition timing otherwise it is all for nought. Rob Share this post Link to post Share on other sites
