Guest ashnicholls
Metal Water Pipe
Guest ashnicholls
How much do they cost new from peugeot?
Cheers Ash
about £12 last time I got one IIRC.
£13.55 at the moment
j_turnell
Or around a tenner if you get trade :P
Guest ashnicholls
Anyone got any pics of where it goes on the 309?
Cheers Ash
rich_w
Same place as the 205? <_< You should see the mounts towards the front of the wheel well (if memory serves me correctly). Do the TU engined cars have these pipes?
You did get a 309 one and not a 205 one?
I can post pic's latter when I get home (5:30 ish) if no one else can help.
Guest ashnicholls
Whats the difference I dont know I just got a peugeot water pipe?
There are the same, No differance
Henry Yorke
I think mine was less with my PSOOC discount :blink:
I was fiddling about on a 106 diesel a while back and i think i saw that they had a plastic "rusty pipe" in the inner arch. Has anyone looked for an alternative? I may just paint mine before I put it on
rich_w
I bought a 'Gates' lower hose for my 309 from GSF - it was a complete hose - no need for a metal pipe!! But I cut it up and used it on a metal pipe as I didnt fancy it so close to the pulleys...
pug309twin40s
i used a 32mm white peice of drainage pipe(that you have on kitchen sinks etc) with a shorter bit of 34mm pipe on outside of it(so if the wheel touched the pipe it would spin the outside pipe without chewing through the other pipe). connected to the hoses on my old 205.
Banjo
XS's have a single rubber pipe front to back, works fine on mine with some simple ally brackets to hold it, no more fannying about with the two 90's and rusted out pipe..
Ben
