allanallen
Before I Put It Back Together
allanallen
right im reconditioning my cylinder head and while its off im thinking of putting in some lairy as fook cam.
but where can i get one from?
im talking cheap!!its a tu3s head and is goin on a vtr bottom end.
what shall i get and where from?
chears mutha puggers!
bren_1.3
try catcams, but nothing O.E is really going to be very lairy. not like a standard XU cam anyway.
possibly have a look at the 106 1.3 rally cam, or an AX GT cam? i dont have any figures on either of them, but i seem to remember those being mentioned in the quite "lairy" category.
allanallen
eh? could you explain this?
bren_1.3
O.E (original equipment / standard) there will be very few standard cams in TU engines that have the "lairy cam" status you talk about, and if there are, they're quite rare and difficult to find for a few pennies.
Rippthrough
Wouldn't the ax gt cam be the same as the tu3s cam? Or am i getting mixed up here?
stu_woac
your lossing it rippthrough lol
for cheap keep a eye out on ebay
allanallen
ok feck cheap i mean £150 starting point but no more than £200
but where? its got to be a tu3s engine one as it has the dizzy drive!
hey but nice one for the help so far!!
Edited by allanallen
Rippthrough
I thought they were both the same cam! ;)
both 85bhp aren't they?!
trogboy
You're bob on Phil, the XS and AX GT cams are identical as it everything else about the engines at they are both K2A (TU3S).
Allanallen - as you are on a budget perhaps you could try and find a cam from a AX GTi. I think these may have the same sized cam bearings as the carbed TU heads. The cams from the later engines that were fitted to the ingection 106s, saxos etc all have larger bearings so they won't swap into your head. I think this includes the 106 1.4 xsi which is ~100bhp as standard.
In addition you need a cam with a lobe on it to drive the fuel pump (unless you fit an electric one) and as far as I know you won't find them on any of cams from injection engines so perhaps the AX GTi cam is no good after all. (just thinking as I type)
Alternatively you could look for a lumpy stick from a TU24 engine out of a euorpean spec 205 rallye or an ax sport. This is a bit hotter than the TU3S cam as standard and it has the lobe for a mechanical fuel pump.
If you want some idea of the kind of spec cam you should be looking for why don't you speak to Matt at QEP. He knows his stuff and would be able to recommend you a catcam if you're feeling flush.
Cams aside, what are you going to be doing about carburation?
bren_1.3
yeh sorry my bad.
stu_woac
yes so you should of replyed the ax gt is excactly the same engine, not question it lol :o
Edited by stu_woac
allanallen
i dont want a oe camshaft!!! kent or cat or piper? i wanted to kno the cheapest place to get one!!
Rippthrough
yes so you should of replyed the ax gt is excactly the same engine, not question it lol :blush:
Hey, i'd been drinking, you just confused me!
Catcams have the best rep. for Pug camshafts.
bren_1.3
buying a performance camshaft "cheap" is probably the worst way to go about looking for a lairy cam, what specs are you looking for? are you looking for a race cam, a fast road cam?
which cam has higher lift? more duration? these are the things you should be asking. not where the cheapest place you can get one is...........what compression are you running? are your engines internals modified? has it had port work? nobody can give you a recommendation until you tell us what sort of cam your looking for
in your first post you said you wanted one cheap, cams arent cheap, at least not in my book anyway. hence the recommendations that you look for an oe camshaft from say a TU24.
youve obviously not thought this through, hence this wayward thread, and not one definitve answer.
Edited by brens_1.9_wide_arch
Guest leegt
if you do want a standard OE cam i would defo go for the 1.3 rallye cam but also fit the inlet mani aswell sounds like throttle bodies also be careful when putting a tu3 head on a 1.6 vtr bottom end cos the compression ratio goes up to 12.1 or higher
stu_woac
1.4 head on a vtr bottom end is no problem at all but you will want to put a higher octane fuel in so running is exspencive
LOL
allanallen
yeah its a xs (tu3s) head on vtr bottom end
bren 1.9 gti i dont know what cam i want? it needs to be used on road as a daily driver but still be good at the traffic lights
not bothered about price!
but surly some places are cheaper than others? so cheap does make sence thats how aconomy works???
christopher
You sound like you want a new cam. But if you are interested I have a 205 Rallye TU24 cam. It has the fuel pump drive lobe.
Catcams will do a cam for your engine. I think mat can get you one for over £200 somewhere..
Edited by christopher
