pugpete1108
What Engine Is This?
pugpete1108
luckily i got a photo before i went to pick up this engine
bloody scrap yards , havent got a clue, just out of interest but what engine is it
Guest cknotty
What Citroen is it in? Definitely looks like an XU of sorts to me. Most likely an XU10, but could be an XU9 from an early ZX possibly?
Banjo
XU10J2 2lt 8v
Edited by Banjo
pugpete1108
they told me it was a 2ltr 16v froma xantia , one weird looking engine tho!
boeseturbo
I´m sure, that is not a 16V! look at the spark-plugs... look like normally XU 8V
pug309twin40s
banjo already got it.
2lt 8v xu10J2, 125bhp.
Guest andy309goodwood
same engine as in the 306 xsi 8v the reason it looks strange is the air box that is mounted on the cam cover apart from that its a std xu10 8v
... i think lol
inferno
good engines those... but if its in a xantia it could be a 1.8 as most 2litre xantias were 16v.
how much are they asking? i sold one in two halves for around 100 quid, also the management should fit a gti nicely.
add a gti cam to that engine and remove the s*it air routes and IIRC youll see around 140 bhp with plenty of tourque...
Banjo
I've got one in me red pug, with the gti cam and a bit of head work it goes well. Baffled sump with trap door and windage tray too..
Edited by Banjo
inferno
that is a xantia btw on looking at the pic again, its very probably a 1.8. should have a badge on the doors indicating so.
pug309twin40s
oops i forgot they did these in 1.8's iswell.
inferno.
they do have the 2lt 8v;s in xantia's iswell.
a friend has 1.
inferno
i stand corrected... ive only ever seen 2l 16vs and 1.8 8 vs in them ;)
i stand corrected... ive only ever seen 2l 16vs and 1.8 8 vs in them :lol:
I've had xantias and xms with 2.0 8v engines.
pugpete1108
they wanted £120 for it but i am looking for 16v power and nothing else , don't think i will ever find a cheap one tho :lol:
i was gonna drive 240 miles round trip to pick it up then got the photo at the last minute , lucky really
don't think i will ever find a cheap one tho :)
You're doing the right thing by looking at old xantias etc, keep trying and you'll find a bargain eventually, trust me. Then, when you've found one you'll probably find loads more :)
Richie-Van-GTi
16v head from s16/gti6 or mi will all fit onto the 2.0 8v easy enough. If you cant find a decent 16v lump get a cheap decent 8v and a known good head of here ;)
