DaveK 0 Posted July 25, 2006 (edited) I have a 2pin wire that is on the same section as the afm (black block with 2 yellow wires). There arealso 3 brown wires loose (2 have spade connectors on them although it looks like a connector block has broken off it, and one with nothing on the end. Also the black L shaped multiblock thing...i have 3 connectors into it and one for the +ve battery terminal...is this right? Sorry chaps, pretty vague i know, ill try get pics up tonight if it helps Thanks Dave Edited July 25, 2006 by DaveK Share this post Link to post Share on other sites
Higgy 0 Posted July 25, 2006 2pin - crank position sensor on top of gearbox? Share this post Link to post Share on other sites
ablister 31 Posted July 25, 2006 tdc sensor is 3 pin. reverse switch connector? Share this post Link to post Share on other sites
d-9 0 Posted July 25, 2006 (edited) 2 pin plugs on the mi16 ecu wiring loom iirc: Injectors x4 (sometimes grey plugs) Ecu Temp sender (usualy blue plug) Idle valve Knock sensor (if fitted) Edited July 25, 2006 by d-9 Share this post Link to post Share on other sites
DaveK 0 Posted July 25, 2006 These plugs are not like normal ones, the direction of each spade is vertical instead of horizontal, if you get my drift does that clear anything up? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 26, 2006 What wiring are you using? Is it the original 205 wires or new ones from the Mi loom? What Mi loom are you using, BX or 405? Graham. Share this post Link to post Share on other sites
