matt205xs
Do I Need This Sensor?
matt205xs
on the front of the 2.0 16v block there is a sensor above the oil sender, it comes out of the block and the connector is on a bracket under the alternator,
is this required when using an 8v loom?
Thats the knock sensor, If using the 8v loom you don;t need it
matt205xs
OK thanks, just to make sure do you know which sensor is which so i have them connected up right?
