Guest farmergiles
Rear Calipers On 205.
Guest farmergiles
i need to get a rear passenger side caliper for my 205.what is the latest model i could find in a scrap yard that would fit?i no vws calipers that are fitted now will still fit older mk2 golfs are pugs the same?
roland rat
i got a set of an 02' xsara vts and they work a treat!you could also get a set off a 306gti6 iirc
Guest farmergiles
do they bolt straight on hand brke connects the same as well?
roland rat
yes straight on!!levers a slightly different on the xsara callipers but are alot stronger imo
ablister
206 gti's definately fit and clio 182's look very similar.
jonnie205
clio 16v
19 16v
zsara
saxo vts
zsara vts
106 gti
206 gti
306 gti
309 gti
all these will bolt staright on
Ryan
Also the Renault 5 GT Turbo
do any of those other cars calipers have different bleed nipples or are they all as prone to rusting and snapping?
jim205GTI
When i replaced the rear caliper on the 306 it still looked the same prone to rusting design ;)
IvarS
I got calipers from a 206 GTi -00 and yes they will rust and snap...in 10 years from now :lol:
